I am pretty sure he should just bow out period but what do I know.
looking for some suggestions for the more seasoned folks on here as i get ready to rebuild things on the crash bandicoot (possible new nickname for my jeep since it is now survived 5 accidents...only one sort of caused by me). here is what i'm still looking for:
long arms...but i think either hobag or rock krawler are going to be my route of choice
wj knuckle swap steering parts...make my own or is there a good option thats not stupid expensive?
rear seats...i want to be able to fit 2 passengers in the back, but i don't want to put the full xj seat in
most of the other things i have or know what i want to buy...i'm going to fix the rear main on the mj and re do the vacuum and a few parts of the wiring. then i will drive the mj and the wj all summer/fall while i work on the xj. hopefully the xj will be mostly finished by the time the snow flies so i can park the mj and get to work on doing everything i need to it...
we shall see
WJ knuckle swap parts...
stock calipers, caliper brackets, knuckles
JKS unit bearing spacer plates
WJ lower balljoints, WJ/XJ upper balljoints (they are the same part, which is why you'll see a million people insisting you need one or the other without any idea why the other person is right too)
99.5+ d30 unit bearings (some people will say certain years of TJ unit bearings and likewise will insist that they have to be TJ ones. Same story, they're the same freakin part, it's the year split that matters.)
Rotors: either explorer sportrac (iirc) or WJ ones redrilled. Depending on which route you go, you have to use spacers in certain spots to make them line up with the caliper bracket. I'd go with WJ rotors redrilled, iirc the center bore on them is the same as XJ ones so they are effectively hub centric not lug centric and getting the lug holes a little off won't hurt anything.
Steering and track bar...
WJ axles are wider so you can't just run the stock WJ rod.
IIRC the taper is the same on the TRE studs (verify this before installing!) so you can just use XJ steering and ignore the high steer arm, but that negates half the reason to go WJ.
If you are considering upgrading steering I would go with 1 ton or heim steering, you're going to have to fabricate it either way so just make it to fit.
Remember you'll have to relocate your track bar mount and adjust track bar length to avoid wonky bumpsteer issues when using the high steer arm on the WJ knuckle.
