*89Laredo*
- Sheffield, IA
I might still be on v4 beta... I dont have that.
I have the same thing Ryan. Must be a iPhone thing???
Still overheats on the highway. Time to play the throw parts at it game.
what's left to replace?
Sounds like the impeller on your pump is shot. Moves enough coolant at idle but doesn't move enough when you are running down the road . Once it gets too hot it can't catch back up
Mac thinks the temp sender is wrong and there's not an actual problem. I can get behind that, since there's no puking or overflow or change in the way it runs. I read some stuff about the o2 sensor making it run lean, so I might put my spare in it.
Yesterday I bought a cap, a tstat, both hoses and I have a new pump in the garage. I'm not sure what else to do. The only thing I can think of beyond all that is a defective radiator.
My stock gauge is off 10 degrees from what the coolant temp sender reads. Ive replaced both the coolant temp sender and the temperature sender for the gauge.
Also there are times my gauge reads correctly ish and there are other times it changes in sinc with the tack. My cluster is getting screwy
If its not boiling over i would say your gauge is off.
