Important
If her out of pocket is only $2500, that will be cheaper than mine.
We've had three ultra sounds and our portion is almost $300 every time...
After insurance our Doc wants $600.
We haven't even touched the hospital bills.
mac 'and that's good city insurance' gyvr
That's still really cheap...
The bill for the twins was $2.9 mil....
Our portion after insurance $17k...
Both drive shafts have been rebuilt and balanced... without the front one in, or rear on in, there's no vibes. Put them both on and I have driveline vibes... Tcase shot?
that is odd.
Does it do it when it's in 4hi?
I suspect that the front shaft is causing your vibe, but only when it's unpowered and free spinning. Put power to it and the vibe stops.
Check the front t-case output.
that is odd.
No, vibes go away when I lock into 4x4...
I'll check the output... I suppose both outputs are probably bad and the chain is stretched as well...
I got a connection that I can get tcase's from for $125, so I might just pick one up and start rebuilding it... Unless someone has one on here for a 97-99 cheaper...
i think i might have found a new pair of axles...don't know what for yet. but i had someone offer to sell me a 78 bronco 44 for $75 and possibly the matching 9" for about the same. i think i might have found the axles that will go in my xj in a few years once the truck is done
Search "cast wedges" dont be afraid of them but do be aware.
yeah if that has cast wedges that is a pretty normal price.
Unless you are in socal and pay like 1200 bucks for a late 70s f350 snowfighter front 60, most of what you spend on a 44 or 60 will be the aftermarket bling, not the initial axle purchase. Unless you are like me and plan on running mostly stock parts on it.
