kmanxj5050
- Reed City Michigan
Bonnies probably getting traded for this Wednesday. 2000 3" lift new 31's, 162k.
Subaru had the NA motors figured out by then. They like to eat turbos because they needed a filter in the oil line for the turbo. there are kits to fix that.
The 05 era cars failed because THEY DO HAVE filters on the turbo. They actually put an ultra tiny wire screen inside the banjo bolt going into the turbo. This thing clogs every 40-60,000 miles. The fact that it could clog always concerned me.... Why would an engine produce solids large enough to plug a metal screen! Premium filters should be catching this stuff long before it gets near the turbo. Also the turbo is bushing instead of ball bearing. My only Subaru experience has been on 2005.5 - 2.5T engines.. (I hauled my former bosses legacy GT and his wifes Outback wagon to the dealer 3 or 4 times in 2.5 years.
Big '.02 unimportant cents... ' Hank
Any Subie under consideration would be an '03 or newer. Basically I'm trying to figure out if I want to go the SUV route or car route.
Please take into consideration what I said in my post
Please take into consideration what I said in my post.... Zero exaggeration going on. When they fail they will break the shaft and puke the oil into the intake duct work and down the exhaust pipe, maybe ruining the cats. There is no good one if it fits the same specs as the 2005.5 cars with the 2.5T
Get your bumstops set up?
you want a 32 for a spare?
http://indianapolis.craigslist.org/cto/2832012757.html
This could be the most honest vehicle ad I've ever seen on craigslist. I was fairly amused by it.
