- NE Indiana
My backup qb is the bears qb...
mac 'i'm screwed' gyvr
I remember asking about this last year and you said "who cares"...Glad to see you're giving it a shot. I'm actually in two leagues this year. The second league I'm in has only 4 teams. I think my secondary could compete with my first string on my other league.I've never played fantasy football before. I got tired of all the folks at working talking abou their bs fantasy team...so I joined a league this year.
...I drafted peyton manning as my qb last week...
mac 'screwed' gyvr
You're heading into NYC correct? If you're going to be in the city Friday during the day, should drop by for lunch. I'll be down for work.
Mac-
Cutler is an average fantasy QB, but he'll keep you on the right side of positive. He's a slinger, so unless he has a 4 interception day, you'll come out with double digit points.
Latest news from my fantasy football insider is that Manning is done for the season. That's being reported by a radio station in Indy. If that's true, Collins isn't the answer for the people that drafted Manning. The wide receiver weapons just aren't there.
red 'played a little' heep
GSGS-
The HPOP on my 6.0 was a $1300 fix. Lots of labor. Good thing it was under warranty.
If you crank it and squirt some starting fluid in the intake (a very small amount so you don't blow something up) and it starts, you know you have a HPOP issue.
The ECU (FICM, whatever) fires the injectors based on oil pressure readings on startup. The 6.0 needs to see 500 psi in that system when cranking. I don't know if 7.3 is similiar. The starting fluid catches in the combustion chamber and spins the engine faster, creating more oil pressure, then the injectors fire and the engine starts. If it starts like that, you need HPOP work.
Got my new header in, now it will only start with throttle and isles real low.
Any ideas?
Until Polian announces Manning is done for the season, he isn't done for the season.
Any ideas?
IAC?
No, I really meant TPS.
