49erRider
- Fort Mill, SC
Ok I searched and couldn't really find any of the same symptoms I'm seeing and I can't find the leak.
Anyways in a 2000xj I just did a 4x4 conversion so new trans/case.
I've been leaking some transmission fluid since the swap. At first it was the cooler lines but I swapped out the fittings and that went away. Next I noticed my cross-member would be wet from trans fluid all across the bottom of it. I cleaned it up thinking it was still from the cooler lines earlier and it would get "wet" again.
Today I pulled the cross-member to take a look and I still can not find a spot that looks soaked or like its leaking other than where the case mounts to the cross-member. Everything involving that was wet. I also noticed a "drip" on the shift linkage on the case. I took plenty of pictures so please please please throw some ideas at me.
Cross member out you can see the fluid buildup is where the mount meets the cross-member.
Underside of mount the part that connects to the 4 studs. You can see the fluid on it.
You can see the build-up where the mount meets the case.
Right Side
Left Side
Shift Linkage with a small drip
Don't see any leakage where the trans and case meet: Left Side
Right Side
Thanks for the help! 2000xj recent 4x4 swap
Right Side
Left Side
Right Side
