freerider15
- FoCo, Crawlorado
Tons eh, gonna be a street queen or are we going to actually get you to do some real wheeling again?
Penrose this spring?
Ha. No. The Colorado naxja page is long dead. Posts every week or every other week from people.
Come to montrose. Talk to ledly, he loved the trails out here and they are easy to get to and fun to run. Some were fun but a touch of challenge, others would require bigger setups or at least another rig with him on his set up. I know a few folks want to come this way for a run come spring.
Yep, I might see if I can stop to/on the way from EJS this year.
Spring Creek would be a decent and close trail for you to hit. You can make it easy, or take some harder lines.
...Not really equipped for Penrose....A cage of some sort, mini boat sides, better/more appropriate wheels, tube bumpers with better anchor points at a minimum....
I bet Little Dirty and I could get it through* as is.
*Slight body damage possible....![]()
D60 front question.....
Noticed that the right front hub is loose on the housing. All 6 hub Allen screws are tight but I can grab the hub housing and it seems to float and can be moved up/down/side to side.
Is this normal? The left hub does this too but barely.
Does this have to do with the hub nuts inside?
You scaring me Troy! I thought you knew how to work on this old-style equipment.
