XJensen
- Sacramento
2001 xj
Jeep would turn on with the key but would not turn over, not even a click from the starter. Few days later it fired up and then on the second start the starter cut out after a second. I checked all the fuses and swapped relays no luck.
I turned the key on and jumper the starter. Cranked strong and started right up several times with this method. Oh I also replaced the battery too it was weak on the amps and better safe than sorry on the trail.
From what I gather this leaves me with the ignition switch and the neutral safety switch. Any way to test these?
I am also thinking of just switching the starter to a push button. I could hook it up directly but would think it would be better to use the starter relay and just bypass the ignition switch and the neutral safety switch. Thoughts? I was not sure how many amps the starter ignition wire pulls. The wire that initiates the starter not the one hooked to the battery.
Thanks for any advice.
