CityRatedXJ
- nowhere
My '01 (4.0L) has been acting up once in a while when started warm and cold. It will idle really really low and I can floor it, and it will slowly rev up, and once it hits about 2000rpms or so it's fine and runs smoothly. The idle is a little rougher than normal too, when stopped while in drive and parked. Check engine light came on a little while after this started and it read cylinder 2, 5, 6 misfire; some emissions problem, and something with the fuel system.
My question here is what could be done to further diagnos the problem. I have to have the vehicle tested for emissions by June 1st, and they won't even look at it if it has a check engine light; I am certain that it will fail because the code was for emissions. I ran seafoam through the engine a little while after it started, and am considering cleaning the fuel injectors. Spark plugs are less than a year old but have about 25k on them, and I have cleaned them every three or four months. Any suggestions or ideas of what my problem is would be greatly appreciated. Thanks in advance.
