ID a steering box / will be used for hydro
CAJJ93XJ
Roseville, CA
Trying to buy a box off this guy to use for hydro assist. I was going to use a YJ box. If I'm going to send a box to westtexasoffroad it might as well have 4 holes right?
This box has been on his YJ since he bought the jeep. I searched the part # engraved in the box but nothing really came up.
His texts:
#6691676
#52
Big 76 cast into the body under the piston.
It looks like 79' GM car or truck, but it's a OEM Saginaw not aftermarket
I believe it's an 800 series box from a 74-77 GM vehicle. There's a bunch of info about doing hydro assist on them. They also supposedly came stock on some YJ's, the 800 series is supposed to be a stronger box."
Here is the link I found on the 800 series box. YJ isn't listed
http://www.speedwaymotors.com/1964-...ing-Box-13-16-Inch-36-Spline-Input,33037.html
bump?
I guess I'm gonna go snag this box and try it out. I'm going to send it to westtexasoffroad for a rebuild and to get tapped.
plans are to run a WJ pump and the redneck ram I've got sitting in my garage. I think it's a 1.5x8
any last advice? or should I just stop overthinking this
throw a pitman arm on it and determine how many turns lock to lock, also, what is the bore off the thing? the "butt" of the box, not sure what you call it, use a tape to measure it? ? at least then you can rule a few things.
Just go and get a 1998-99 Dodge Durango steering box, then have it taped for hydro. The box has upgraded guts and still is the same mounting pattern. You can use the YJ as a core since most can't even tell they are different.
