Rebuilt steering box problems
Shaneo417
Ladysmith bc
Hey, long time reader first time asking anything.
I’m building a 98 xj right now and currently having problems with the steering gear. I just rebuilt the Saginaw box and tapped it for hydro assist. I tapped the top plate and the end plug. Box is in ram is hoses connected I bleed the system and it seemed perfect. A little hard to steer but not terrible. Then all Of a sudden it starts to turn right on it’s own. I can move it centre but still wants to pull right. It does it if the ram is connected to the tie rod or not. Motor off ram disconnected and turn left and right ram moves the way it should. Did I bang up a seal in the box during rebuild? I’m kinda confused
Take it apart and look at everything. It isn’t the ram causing it to turn right. It’s the rebuild.
It could be a seal. Maybe the number of Steel balls is off.
Does it go all the way to the right or just a little?
Yeah that’s what I was leaning towards unfortunately. Something in the box. It dosnt go all he way to the right but I can hear the fluid in the box as if your turning the wheel trying to turn it right when engine is on. That’s actually the page I used for the rebuild haha thanks for your help! Time to take the box apart again I guess :(
