- Wasatch Range
MMMMM....Good.
jeepcherokee95 said:Ok, I looked through my "research material" and did not find the writeup on exhaust but someone did an excellent job on a writeup recently giving pipe sizes and tech info on why this set-up is better than that ect...
If someone finds it could you please post it here?
Next question:
I am trying to make the best flowing exhaust with stock manifold (I can't afford a new manifold) I am after MPG NOT HP!
My thoughts are this; go from the exhaust outlet into 2.5" to the hi-flo cat, through the cat to a flowmaster40 muffler then go 2.25 out to the tailpipe.
Would this work or do I need to stay at 2.25 all the way?
If I were going to do the dual I would just make a "Y" pipe right out of the hi-flo cat and go into the dual mufflers but with any dual system on any I-6 I think that it would be too free flowing and you would loose low end torque, response and even mileage - just my opinion.
JC95
Dr. Dyno said:Hey, what's wrong with an old soup can?A Campbell's soup can does the job very well. You can spray paint it on the outside in your favourite colour to make it look good, or even powder coat it if you feel that way inclined.
Bloose said:Once your past the cat I don't think it matters much if it flows too much. So if a dual look is what your after, go for it. As far as the 2.25 tail pipe that should be no problem. As the exhaust gets further from the cat it cools, as it cools it has less volume so it can flow through a smaller pipe. As far as a 2.5" pipe possibly being to too large off the manifold I don't really know. I don't think it would be a problem but without dyno numbers I'm only guessing. Personally I think the stock exhaust tube exhausts are pretty good with the excection that they like to crack. For flow though I think they're fine.
B
B
thedarkprince said:Wouldnt the smallest pipe size be the control? I understand that the air does cool down past the cat and reduces volume accordingly, but how much difference would a 1/4" in diameter make way back after all that? I mean once you have you're smallest pipe being whatever it is, whatever is bigger behind that, I mean, would going from a 2.5" to a 5" TAILPIPE really matter? (no I am NOT going to put a ricer 5" tailpipe on, its just an exaggeration)
FUNKYTEE5 said:The most important pipe diameter is what hooks up to the header and runs back to the muffler/cat. From there back it can neck down (2.5-2.25) slightly due to exhaust gasses cooling/contracting and there will not be any adverse affects unless you have a race motor or sumptin. It is good to have free flowing exhaust from the muffler back, but the head pipe diameter will mainly determine how well and at what rpm the system will scavenge exhaust from the cylinders. Backpressure is often mixed up with scavenging and they are not the same! Scavenging is when the velocity of the exhaust gasses through the system will help pull exhaust out of the cylinders at a certain rpm
FUNKYTEE5
