I need a motor
Good Answer! Wish I had thought of that! John, Let me know if it falls thru I'll give you the guys #!
Thank you sir. I am planning to pick the replacement motor up this Sat and then get some work done on it. I will replace the timing set and maybe the rod and main bearings if they are not perfect. I plan to have a valve job done on the head and that should ensure it is a reliable engine for the next 100K miles or so. When I put it in I plan to do a bypass oil filter I bought but haven't installed yet. I am debating continuing to use my oil accumulator because it hasn't worked perfectly and it needs a separate air reservoir to work at full capacity. I hope to be putting the newly refreshed motor in in a couple of weeks. I will post up for a work party if folks want to help out. I will need an engine stand and hoist if anyone has one available. Thanks guys for all of the help. You guys are what makes NAXJA the most awesome jeep club in existence!
