Mike L
- Anaheim, CA
Lincoln said:I do have a few things going for me.
1. I'm not from the midwest.
2. I weld better than you.
3. I'm not from the midwest.
:shocked: :flame: Got Burned?
CRASH said:And here I thought you just had your Harbor Freight knob turned down to minimize crappiness!
SeanP said:...
wish I had 3-phase electrical at home![]()
Lincoln said:...
His TIG is a 300 amp single phase. I'm guessing that would be around around a 40 240v draw and it would probably be setup for a 50 amp service. Is that about right?
Lincoln said:...
I kind of lucked out. My house was built with electric heat so I ended up with a 250 amp service. The electric heat has been romoved so I should have no problem running whatever I like.
Lincoln said:...
I'm really need to look into forming a "I hate the Captain" club.![]()
Lincoln said:...
I would really like to have a decent sized multi process machine and tag on a wire feeder. I'm still using my little mig (175 home jobby) and I fire the stick box up once or twice per year and that's usually to practice so I'm not setting new levels of crappiness when I need to use it for real.
Lincoln said:The TIG I would like to have for aluminum. I do ok with the MIG but it can be a real PITA some days. I trashed three tips setting it up for about 18" of weld one day. I'd hit the trigger then it would pop and weld the wire to the tip. No matter how quick I was it would still mess up the wire at the rollers. A spool gun would work but TIG seems like it would be easier.
Lincoln said:One more queston. If I bring the welder to bed will I become better by being one with the machine?![]()
I don't think they make rollers for that small of wire Lincoln...Lincoln said:One more queston. If I bring the welder to bed will I become better by being one with the machine?![]()
FarmerMatt said:I don't think they make rollers for that small of wire Lincoln...
Ron,
Very cool info. I only wish I could weld like that. It's sexy wnhen you get down, dirty & technical... or maybe it's the hair. You need some one to test out your flange thingabobbys?
Matt
Matt
FarmerMatt said:...
Matt
Lincoln said:...
The other part that gets me is overhead welds. Right or wrong I like to crank it up and move quickly to keep from burning holes. 3/16 I can get close to what I like but occasionally I do some 1/4 and I just have a crappy time at getting a decent weld.
Lincoln said:I've looked at moving up to something like a 210 but then I think about how the $1200 would go quite a ways towards a multi process box if I shop well. Then when I'm messing around with aluminum I would have a pretty decent setup. I would be happy with 200 amps on it.
Lincoln said:Next time I'm working on this I'll let you setup a tent in the neighbors yard (you can ignore the lack of level floatation):
GSequoia said:...
real Advanced Fabrication Tools.
Captain Ron said:I'm hoping I get to see them in action this weekend at JV...
Captain Ron said:The owner made it out, but not the rig. We'll have to wait for the next run.
--ron
Mike L said:Cool, then I didn't miss much. Where are thie pics and updates on your rig? :shocked:
-Mike
