so after a look to make sure. i have the large bearing spindles. which makes sense with the 8 lug pattern. so i need the small bearing spindles. what bearings do i need? is there three total, two wheel bearings and the inner spindle?
ford rotors and hubs... correct?
the stub shafts i have are ford. will i need new ones running this setup?
model: long side - short side - stub shaft
F150: 18 29/32 - 33 29/32 - 9 23/32
F250: 18 5/8 - 34 3/4 - 10 21/32
Chevy: xxxxx - xxxxx - 9 15/16
FSJ: xxxxx - xxxxx - 9.93 (roughly 9 15/16)
obviously chevy is pass drop, and FSJ is a different width. but i i read on Mr.N's site to use the stub that matches the spindle. im assuming this is to make sure the snap ring fits? my axle came with all ford stuff... anyone running ford stubs on chevy knuckles? my axle has 1/2 axle tubes, and the HD housing, how can i verify that its not from a F250?
