Thanks! I'm probably not doing to good with the simple explanations now.
So now that I know the pinion depth is good, I can now set the pinion bearing preload. So out comes the carrier and the pinion gear, and now I can install the shims you see below. There are 2 - .025" shims and 1 - .001" shim, same as what was on the old pinion. And I will install just these parts, leaving out the pinion seal and still using an old pinion nut.
I tighten down the pinion nut checking the turning resistance of the pinion as I go.
If it starts to get too tight before the pinion nut is all the way tight, I will need to stop and add more shims, I don't want to damage the bearings by over tightening.
If there was slop or the pinion turns real easily by hand, I will need to remove shims.
To get it just right, the turning resistance needs to be measured with an inch lb. torque wrench and the spec is 14 to 19 inch lbs.
The first time I did not get hardly any turning resistance when the nut was tight, so I took the pinion back out and removed 1 of the .025" shims, and I installed a .020" shim.
Here's where you need some patience when installing gears. I know i'm gonna mess with this awhile and I also know that the carrier shims are gonna need some changes.
So after that last shim change, I am reading about 20 inch lbs. and the nut is not all the way tight, so I'm gonna have to add a shim. It's close though, so I'm just gonna add a .001" shim.
After adding a .001" shim, I set the blue needle to 0 and then turned the pinion, and blue needle moved to the max resistance I had, sort of like a tattle tale tach. I got to about 13 inch lbs.
So now I have a descision to make, if I put back the .001 shim I am above the spec. for the pinion bearings, and If leave it out I am slightly below the spec.
Sometimes you can swap around shims to get different readings, for instance using 2 - .010" shims in place of a .020" shim, will sometimes take up more space than a single .020" will. I need to remove less then .001" though, I tried two combinations before I was happy, first a .010" and a .005" and 4 - .001" shims, that was too loose, worse then before.
So then I used a .010" a .005" and 2 - .001" and then it was good, 18 inch lbs.
Don't ask me why combining several smaller shims adds more than a single shim will, but it does.
It probably would have been fine to leave it at 13, and if I had to chose, I would want it a little loose, instead of too tight.
Now I can pull the yoke off one last time and drive in the pinion seal. And then install the yoke for the last time and I will now use the new pinion nut.
By the way the old inner pinion race fits the seal just right and makes a good tool to drive in the seal without damaging it.
