Infidel_XJ
NAXJA Member #1065
- Afghanistan & TX
So after purchasing this built HP30 last week, seems plans have changed. It’s going back on the market. The axle is at RoyalXJ’s place in NJ and MUST BE PICKED UP. I’m asking $1750 for the axle, OTK, and shortened RD trackbar. I’m not looking to split it up, being sold as a package only. If I don’t sell it by the time I get back from Afghanistan, I’ll end up using it, so the price if firm and well worth it.
Axle: HP30, Cryo'd 4:56s, Detroit Fullcase Locker, Alloy Shafts, Spicer 760x Joints, Alloy Tube Seals, Spicer Balljoints, Riddler Dif Cover, T&T Truss w/ OTK Track Bar Bracket and Control Arm Brackets, Relocated Swaybar Mounts, Clayton LCA Mounts, Welded Axle Tubes, EMS Offroad Hub Conversion (Hubs, Spindles, Rotors, Warn Premium Lockouts, 4340 Stubs, Timken Bearings). Knuckles are reamed for one ton OTK steering. Built in June 2010. WMS-WMS is 62.5” and C-C is 53”. Hub conversion takes a wheel with a hub bore of 3.45”. Most steel wheels run around 3.3” and will need to be slightly bored out (lathe or die grinder).
Steering: One Ton OTK, 1.5” Ballistic Fab 7075 tie rod, 1.25” DOM drag link with Moog TREs, 2 are brand new and 2 have 1 trip of use on them. Spare ES2026R and ES2233L are included. Trackbar is a shortened RE1660. Comes with Bored out Dropped Pitman Arm.
