RoyalXJ
- West Deptford, NJ
HP30
-Yukon 4:56 gears
-Fresh Timken pinion bearings
-Fresh inner seals
-Lock Right locker
-stock shafts w/ 1 chromoly stub shaft
-1/4" lca brackets w/ skids
-Inner C braces
-OTK track bar mount
-HD passenger upper control arm mount w/ RE super flex bushing
-welded axle tubes
-coil buckets are boxed and skidded
-Superior tube seals
-Riddler diff cover
-newer Spicer HD balljoints
-Timken unit bearings
-WJ knuckles w/ JKS adapter plates welded on
-WJ dual piston calipers
-JKS 1.25" .50" wall DOM tie rod & draglink. Set up over the knuckle w/ goferit inserts welded in the knuckles
-steering stabilizer and u bolt clamp
-Crown HD u bolt 1310 yoke
-1.5" .250 wall DOM track bar w/ ruff stuff heims
-Rubicon Express track bar bracket
-Comes with Ballistic Fabrication truss and Ballistic 2.0 flex joints to make it 4 link again
C8.25
-Yukon 4.56 gears
-Powertrax locker
-welded axle tubes
-shaved center section
-Alloy USA 29 spline shafts
-ZJ disc brake conversion
-Ruff Stuff diff cover
-raised shock mounts
$1800 for the pair
Woodbury, NJ
-Yukon 4:56 gears
-Fresh inner seals
-Lock Right locker
-Inner C braces
-welded axle tubes
-Riddler diff cover
C8.25
-Yukon 4.56 gears
-Powertrax locker
-welded axle tubes
$1800 for the pair
Woodbury, NJ
