BillR
Toy Jeep driver!
- Flagstaff, AZ
Here are a few pics of my winter project. I just have to install the "guts" now... :repair:
The brackets are from an RE kit, with some JKS extended swaybar links and a JKS OAB for the trackbar. I also put some gussetts on the passenger-side UCA mount.Big Red said:Did you custom make those brackets or are they RE stuff?
'76 F-150. It's been cut down to use late Waggy inners.Root Moose said:What was the donor axle?
r@m
So you retubed or is the cast part for the Ford CAs still on there?BillR said:'76 F-150. It's been cut down to use late Waggy inners.
Mine had welded-on radius arm brackets. I cut them off and ground down the weld.Root Moose said:So you retubed or is the cast part for the Ford CAs still on there?
I ask because I have a F250 tube that I want to use for a non-XJ project and it looks like the cast in spring pad will interfere with REs brackets. I should fab my own bracket I suppose.
r@m
Waggy inners, Ford outers, x760s, Ford rotors/hubs, Chevy brakes.Goatman said:So, what axles are you putting in it?
Table Mesa?
LOL :laugh3: Not a chance! I don't have enough rig for that stuff, although I may cruise down and watch.Fergie said:I'll buy his gas if he runs Table Mesa with BOTW and I can ride shottie.
There's some motivation for ya :gee:
Fergie
Don't you mean you have too much paint for that stuff?BillR said:LOL :laugh3: Not a chance! I don't have enough rig for that stuff, although I may cruise down and watch.
:laugh3: Goatman PM'd me and said the equipment restrictions were pretty stringent. Too much paint? probably! :laugh3:Okie Terry said:Don't you mean you have too much paint for that stuff?
And where's the shine on that axle, pal?
I'll take your word for it! :wave:Goatman said:Yeah, you'd have to be sick to run an '01 through the Table Mesa trails we'll be running.......![]()
Bill,BillR said:The brackets are from an RE kit, with some JKS extended swaybar links and a JKS OAB for the trackbar.
That part was EASY! You can see where the bottom of the bracket is welded to the axle tube. I sent you a pic of the top via email.TRNDRVR said:Bill,
Can you shoot and post some detailed pics of this stuff? Or email them to me?
I want to see how you integrated the JKS OAB into the RE bracket kit.
Thanks,
Dan.
