Jarvis_Pants
- Doha Qatar
Im looking at a performance cam and was wondering what the easyist way to up the redline or remove it intirely.
Thanks in advance.
Jarvis
Thanks in advance.
Jarvis
x2, Its no DOHC engine.Dr. Dyno said:I looked into the idea of raising the rev limiter last year but decided not to bother for three reasons:
2. Anything above 5500rpm would be suicide and even if you raise the limiter to 5500rpm, the performance advantage over the stock 5200rpm limiter is minimal.
3. The torque curve starts to drop off more quickly above 4500rpm and by 5200rpm the engine's already well past the peak HP point as well.
streetpirate said:convert to megasquirt and find a gear drive, usually forged from pure unobtanium and commonly found on orbiting space rocks
gradon said:I just want to hear from someone that has raised their rev limiter.
CommandoXJ96 said:and im here for pictures of the carnage that ensued.
Flash said:I beleve that it is true............but i would love to see some CARNAGE as well!!!!!arty:
Flash.
XJLafonda said:You guys are SICK!
JJacobs said:I keep hearing about all these harmonic issues. Who's got pics of busted parts caused by overrevving?
JJacobs said:Maybe they do, I never called to ask. I doubt anyone else on here has either. Just seems like somebody mentioned harmonics at one point and now everybody's saying the same thing, because someone else said so too.
When I took an old 4.0 to 6400 the alternator bearings failed instantly. Dang harmonics!
