How to remove tubes from a Dana 44?
92SportXJ said:
Awesome work !
I have been in contact with TnT and they told me that they are working on a truss system for the LP 44 waggy housing now. So I have decided if I want to hold on with my waggy housing or start looking for a HP 44.
Chris
IMO If there was a chose between a low or high pinion. No Question on the high pinion. Shortening the axle is not that bad of a job and you will want to correct you caster no matter what axle you go with. Plus TNT's High Pinion 44 Conversion takes about 1 1/2 hours to put on. No measuring really needed. It's pretty easy to install the truss, spring perches, and lower control arm brackets. Plus Matt from TNT and I worked on the track bar bracket set up and they should have exactly what you need if you decide to run a true high steer set up.
