I noticed the rear brake line on the passenger side hangs down a lot. Is there a common way to relocate it so it doesn't hang down so bad? I did a search but no luck...
I don't think it is considered a hard line, it is where the line connects to the drum, it goes down below the axle, and I have noticed it is the same on every cherokee I have seen.
Are you taliking about the e-brake cable? I used a wire tie on mine and attached it to the axle, its all I had at the time..A spring would be better.
Mine actually came off the shoe and fell out of the backing plate....scared the s-it out of me when I ran over it, that sudden jerk made it feel like the whole drivetrain was falling out.
I just bought the jeep and looked under there real quick, it could be the e-brake cable but I would have to check...but every stock cherokee I have seen driving around has the same thing...i will just zip tie it for now.
