Howey
- Anchorage Ak
Thanks for the info. I'm going to try to lift it with in the next few months.
Howey, I'm guessing from your last post that you have time to build it up slowly? If so, consider cobbling together your own lift from other parts. Front end: ZJ V8 coils will give your front end a lift that you can level out to 3" with coil spacers. You can bend your front brake lines to get a couple of more inches of length. You probably don't need new control arms at 3" and under. Get swaybar disconnects for the front end. You can get bar pin eliminators front and rear to get more shock options.Howey said:Well I just got home and found a 3" lift for $378.00. It's a skyjacker. I also found 31/10.5 and rims for $638.00. The only thing I have to find out is if the rims I'm thinking about buying are stock, if so then I'll keep what I have and just buy a spare. My friend and I are going to install it in his garage (he has way more tools than I do). I'm thinkin about buying Rancho 5000 for it but I really don’t have a clue what length I need. Any suggestions? I went to the website mentioned before but I'm a nubbie so it really didn’t make much sense.
Thanks for any help.
Howey said:Well I just got home and found a 3" lift for $378.00. It's a skyjacker. I also found 31/10.5 and rims for $638.00. .
Howey said:I'm new to this sort of thing so please forgive my stupidity. I have a 99 Cherokee and would like to put 31's on it. I heard that I would need about 3" lift, is that about right? Any help in this matter would be great. Also I live in Alaska and it's crazy hard & expensive to have things shiped up here.Thanks
Howey. Before you give up on finding used pieces to put something together, try Dean's Auto Salvage and Northwest Auto Parts. Both are in Anchorage and both have plenty of Cherokee and other truck parts. Leaf spring packs for $60 etc....Howey said:Thanks for all the help but I think I'm going to go with this kit. I did some looking and I could piece one together it would actually cost about the same because of my location. Stuff is not cheep in alaska and some stuff is kinda hard to find. So it looks like I'll go with the zj shocks in the back thanks for the info.
Howey
I looked through car-parts.com to find them. I searched for xj leaf springs in alaska and ended up with those two sites being major contributors to the list. They seem to carry lots more than just jeeps. By the way, when thinking about replacement leafs for your leaf packs, just about any 2.5" wide leaf will do, including older Jeeps, chevy trucks, dakotas and many others to choose from. Just a thought.....Howey said:Be the way how did you locate those sites? I tied google but must have typed something wrong.
