Oseberg said:Need to know qty of splines on the input/output shaft on a AX 15 transmission fitted on a 97 mod..
(Have a XJ 97 4,0L and may buy a 94 mod. transmission)
Will this fit ?:eyes:
Oseberg said:Does it matter if the quoted one is from a Wrangler?
Any difference in axle diameter ?
I installed a np231 out of a '92 Wrangler into my '88 XJ sometime back, and there was no differences in the clocking.Jeff in VA said:Wrangler trannies are the same, but the holes for the transfer case studs are clocked about 10 degrees furthur clockwise than XJ/MJ trannies. You may have clearance issues with the floorpan and the transfer case, but nothing that can't be fixed with a BFH and some gentle persuasion
Jeff
Oseberg said:Interesting......
What you are telling..........there are som Toyota suv's going out there with AX15 Transmissions identical to what I have in my XJ ?
If so, witch Toyota model are we talking about than ?
Jeff
5-90 said:Or just swap transfer case adapters, and call it good. That should only take a few minutes...
