91 Limited w/Bendix-9 ABS.
I replaced a rear hard line and wheel cylender, and bled it out, and in the process of bleeding, the pedal was pressed 50+ times with the power off. I know this de-pressurized the ABS system.
Now that the system is again closed, how long should the pump have to run to rebuild the pressure in the system that was lost during the repair?
I'm just worried about letting it run until it stops in the event that I let the fluid get too low while it was sitting, leaking, waiting for me to fix it (a week). I don't want the pump to burn out or anything.
Thanks
Thanks
