How hard to swap wagoneer 44s into a cherokee?
It depends on your capabilities. buy or make brackets, measure and place appropriately, set pinion angles, weld. And replace all of the broken and rusty parts.
Since they are matching you won't need to regear if you cant afford it yet.
Look at the bottom of the page for LOTS of similar questions and threads
can you measure and weld? if yes then you basically have the ability to swap these under an xj.
they are the easiest axle swap you can do pretty much. just to a little research before you dive in and you will have no problems.
