House Insulation question
DutchVDub
Milliken, CO
So I'm wanting to insulate the roof of my garage but keep the open trusses as I like being able to store things up there. Can I just put the fiberglass insulation right up against the roof? I figure I'll have to leave the vents open, but do I need to worry about leaving the soffit vents open and/or an airway from the soffit vents to the peak/roof vents on an otherwise open garage? The walls will be drywall and insulated up to the "ceiling" joists.
I am not a contractor, but as I recall you have to install something between the insulation and the roof to allow airflow from the soffits all the way to the vents to prevent moisture buildup. I believe they make plastic things that you can attach to the inside of the roof specifically to keep that small air gap while installing standard insulation.
Yep, I figured it out. It probably wouldn't be a huge concern in my garage as there won't be a finished ceiling or regular climate controlling, but my options are to either use something similar to what clouded linked or use spray foam insulation. As the R30 batting is already pretty pricey, plus now the added cost of all those venting panels, I'm going to call for quotes to just have the roof spray foamed in the garage.
You still need soffit to peak vent air movement, even if you spray foam, for the life of the roofing materials... make sure the guy who bids your foam includes the baffles.
Also, the Kraft paper face on batt insulation is considered flammable. By code, it has to be covered. An errant grinder spark could ruin your day.
Sent from my SM-N920P using Tapatalk
The closed cell spray foam doesn't require an air barrier between it and the roof plywood because it is both a moisture barrier and non-air permeable. Meaning the warm air from the garage would never reach the cold plywood of the roof to condensate against it. Any condensation would merely collect on the surface of the foam. You need a 1" air gap between fiberglass insulation and the roof plywood because warm air from the heated garage can permeate the fiberglass, then hitting the roof and creating condensation against the plywood. Without an air gap the moisture has nowhere to go and the wood can't dry back out.
How big of a concern is it with my only intermittently heated garage, whose to say? The 200$ for the plastic panels that create/maintain said air gap is cheaper than a new roof, so I'd go ahead and spend the extra money.
Yes, if using faced insulation I would then need some sort of 15 sec fire barrier between it and the rest of the garage. Although my worries of a grinder spark reaching 12ft up into the rafters and still able to catch fire to the paper are fairly minor.
I just got a quote for 1100$ to get a 3.5" thick (equaling R20) layer of spray foam put on my roof. By comparison if I use R19 fiberglass bats and do it myself I'm looking at approx. 600$ based on Home Depot website pricing for all the materials. I could theoretically spend the extra money on R30+ fiberglass and be at 800$, but in both cases I'm having a hard time via Home Depot's website of getting unfaced insulation. So then I would also have an added cost of some sort of fire barrier. I'm not tiling my roof with drywall (would have to cut it down pretty small to get it between the joists) and I'm not sure what else I could use. I guess I could always just put the paper facing towards the roof and call it a day. $1100 is a lot to swallow for the spray in stuff, but it does save me a lot of work/time. It also saves me a lot of itchiness. If I do it myself though I can always just do a small section at a time and spread that cost out over a few paychecks.
Just for fun, based on the square footage of my roof the mathematical perfect world difference between R20 and R30 insulation is about 260btu's of heating requirement to maintain my garage 40deg warmer than outside and 340btu's at 50deg warmer than outside. My garage heater should be putting out about 20,000btu's. Currently with my garage completely uninsulated it should take about 40,000btu's to maintain that 40deg temp differential. With figuring my garage door at R0 and not counting the wall that faces the house (as its both insulated and the other side is at 70deg) it should take 9,600btu's to maintain that 40deg temp differential once I get done insulating the walls and roof. That drops down to 3,500btu's in a perfect world with the R5 garage door foam insulation kit. In the end my little heater should have no problem keeping things toasty once its all said and done.
Of course, not counting the electric bill I could just save all my money and simply buy a second 6kw garage heater for about $200 installed price. That gets me up to my 40,000btu's of heating requirement and saves me a ton of work and money. I don't pay the electric bill anyways and its not like I'm heating my garage 24/7.
Ok, just saw this. I'm wondering if it'll be the ticket.
http://www.homedepot.com/p/Thermash...-Rigid-Foam-Insulation-Board-613010/100573703
Perfect math world here but at just under 400$ I could just use this to "tile" my rafters and only be down 400-600btu's of heat requirement. If I go across the rafters then there will be a 3.5" air gap between it and the roof plywood. That should negate any issues/concerns there and it has an aluminum facing so there shouldn't be any fire hazard from grinding.
You need to ask the Authority Having Jurisdiction, i.e. your Municipal/County building inspector.
If you meet their criteria, your insurance company has nothing to bark at.
