Horn Acting Up
A15ltzz
Pittsburgh Pa
Got an interesting issue with the horn on my 98. I replaced the clockspring which fixed my airbag light issue, and the cruise works fine. My horn though will only work if either the Jeep is not running or if power is not turned on via the key. Sounds like it might be a grounding issue but before I remove the airbag and go tracing wires, was wondering if someone else has run into this issue. Thanks!
