Hood vents, scoops etc. Heat extraction
I had my exhaust "manifold" off to weld up all the cracks.
While it was off I put a ton of header wrap and also fabricated a sheet metal heat shield
Then I made a hood hinge spacer kit with longer bolts
I assume this has prevented any underhood temp problems
The welding and header wrap means it's gonna crack again. Soon. :D
I've tried hood vents, but the Reflexxion steel cowl hood is much more efficient.
ZJ Hood Vents
Reflexxion Cowl Hood (No Longer Available):
