HO intake part
Jess
Tennessee
I need a HO block-off plate for the egr. I know the HO does not have an egr, but the intake still has a hole there. I am going to try to mount the plate on a Renix intake instead of re-using the egr.
RedHeep said:
Have a picture?
I have an HO intake in the garage.
I don't have one right now, but can take one if needed. It is on the opposite side of the manifold from the mounting surface to the head. It is a small plate (about 2x4...I think) with 2 torx bolts (i think) in it.
There should be no "block-off" plate for that - the HO didn't have an EGR. Only RENIX did.
If you absolutely need one, you can make one out of any flat piece of plate steel - say 1/8" thick. Use a new gasket when you install, or some RTV Copper.
Have you sorted out what to do about the EGR tube, if you have one? I don't have measurements on those threads anywhere I can think of...
I got a new exhaust manifold, which has a plug in the hole where the tube would go. I will also plug all of the vaccum lines.
