Highest compression ratio?
Talyn,
To answer your question; How? My block was bored 0.030" over and after some calculations the block was milled down so that the top of the Venolia pistons were close to the top of the block.
That still doesn't get you 11.25:1. Its more like 10.87:1.
Talyn,
The static CR I got, both with hand calculations and running Performance Trends Engine Analyzer with my final dimensions and volume measurements, was as I stated.
Best regards,
CJR
First off, a more reasonable compression with an iron headed small cammed engine is 9.7:1 at the most.
Second, quench really starts to deminish after .045 so I recommend .040 as a target.
I'm building my Father-in-laws stroker with mild porting to help port velocity, diamond pistons for 9.7:1 compression, and a custom 212-216@ .050 cam on 110lca.
We will be dyno'ing the engine on our DTS dyno in Feb. so I will post results. It will have the better intake, TB spacer, and header.
With inline 6's, I treat them like imports...a little here, and a little there makes decent gains in the end.
Brian
Talyn,
The notes, on my saved Performance Trends 4.0L engine run, indicate "56.5cc/chamber". That number seems to ring a bell as the number I magic marked on each chamber after CCing/adjusting them.
Best regards,
CJR
CJR: What injectors and spark plugs are you using? Do you know the comp/pin height of the Venolias?
Gradon,
I used Ford injectors. As I recall they were about 19lb/hr and work well with my MAP electronic gadget to increase injector dwell. The spark plugs were standard Champions, Copper Plus?. Without digging out my detailed notes, I don't recall moving the height location of the pin on the Venolias. The forged flat-top Venolias (no dished top to reduce CR) were spec'ed as follows:
1. Pins offset, like the standard 4.0L piston.
2. Top compression ring groove moved higher up and closer to the top, i.e. a Smokey Yunick recommendation.
3. More holes drilled in oil control ring grooves to allow sufficient oil drain back to crankcase.
4. Ductile iron top compression ring used with standard width. Stainless steel compression rings are now more readily available in 1/16" widths and that would now be a better choice.
Best regards,
CJR
Gradon,
I decided to pull my forged flat-top piston card received from Venolia. I did not use standard ring widths. The ring widths were; 1/16", 1/16", 3/16" and the top ring located closer to top (couldn't find the actual dimension but used Smoky's recommendation). I insisted on more holes in the oil ring grooves for better oil drain-back to crankcase and the prevention of low mileage carbon sticking of oil rings. My bore was 3.915", stroke 3.441", pin diameter 0.931"(used lightweight Sealed Power pins). Piston part number was; 6610, Job No. 128691. Rings were Total Seal. Pin holes in piston were offset the standard amount to reduce piston slap noise. I had my local machine shop reduce the pin lengths and install TruArc locking rings, hone the pin holes for free-floating pins, and drill oiling holes for the pins. I used standard rods, polished and shot peened. Engine was balanced.
Best regards,
CJR
Talyn,
Best regards,
CJR
Are you sure it was not 66.5cc's?
All of the 4.0L heads start with nominal 66 cc chambers.
Ed,
Before I started the 4.0L head work, I talked to a AMC racer about how much material was available in the head for milling. In the past, on other engines, I've actually bought cracked heads, band-sawed them lengthwise and sidewise and measured available material for milling.
Using a tracing of the ported combustion chamber and a planimeter to measure area, calculations were then made to estimate how much material had to be milled off my 4.0L head to get 56.5cc. The head was then milled to get 56.5cc. Then initially, the volume of each combustion chamber is measured & marked. Those chambers slightly under 56.5 cc are lightly reground/polished to get closer to 56.5cc. These "massaged" chambers are measured again and the process repeated as many times as necessary until all chambers measure close to 56.5cc. There are many volume measurements made to verify volume measurements or pick up errors in volume measurement.
Best regards,
CJR
Before you spend $$$$ and not know where you are going with the build, buy Performance Trends EA3.4 (or the older EA3.2) to model and research the relative output gained from the various combination of parts you are thinking about.
If you are not familiar with SCR, DCR, overlap, BSFC, valve sq-in degrees, fuel #/hr, and the difference between mild and wild cam ramp intensity, the engine analyzer will help you teach yourself.
You could also purchase Internal-Combustion-Engine-Theory-Practice (volumes 1 & 2) for the same money and spend a year digesting the knowledge (with less favorable results).
Either method of modeling (computer modeling or old school calculations) will save you more than the cost of the education in parts and in knowing the parameters to have double checked during the machine work.
I wouldn't say the results from reading Taylor are "less favourable" than playing with EA (I've had EA, I have both volumes of Taylor, as well as many other "definitive" works on the four-stroke IC engine,) it really depends on how you learn.
If you have an academic tilt, the books will be just fine - easier to refer to, and you don't have to worry about transferring them to a new computer.
And, having both isn't bad - because you can learn it from the reading and see it in the sim, or see it in the sim and have it explained to you in the books.
I haven't compared the results with EA to the "real world," but engine sim programmes are useful. However, it should be borne in mind that there's really no way to model for all parasitic drag in the real world - when using a more low-buck engine sim (like, say, Desktop Dyno,) figure that real world results are going to be about 5% lower than sim results - the computer simulations can usually be taken to be "optimistic." Just how optimistic depends on what model was used and how many variables were coded into the programme.
That being said, engine simulators are still useful for providing an "apples-to-apples" comparison of various parts swaps - key in all of the baseline data, and play around with cam profiles, for instance. You can still figure out a lot without turning a wrench! Just remember that the results are, indeed, going to be a bit better on the comp than in real life.
I've worked with EAPro - and I'd buy it, if I had enough spare nickels floating around (I need to buy something - upgrading to Win7 64 killed a number of my legacy apps.)
Taylor, Blair, Richardo, et al all do make for some heavy reading - if you're not ready to try to figure out what they're talking about, you may find it too much. Problem is going to be trying to find these books at a library - I bought them because I couldn't find them anywhere around here (and even that took some doing to get them for a more reasonable price on eBay - considering the sort of pricing you'll see from MIT Press or SAE Press...) Bentley Publishing, as I recall, has some good books on IC engine theory - that are a bit closer to layman's terms and cost a good deal less. You may want to peruse their site as well.
@CJR - do you have any pix of your sectioned heads? I want to do something similar with 6-242 heads (I've got a 2685, 2686, and 0630 head so far - need at least one 7120 and 0331. I also want to be able to save a cylinder section for porting experiments...) and I'd like to accumulate as much data as possible.
5-90,
I do not have photos of a sectioned 4.0L head. In the past, I have sectioned Chevy small block heads before extensive porting and polishing. Likewise, I've sectioned a Ford Cortina 4-banger head that, with a Crane specially ground cam and a CR of 12.5:1, Venolia forged pistons, ram-tuned intakes and exhaust (@max. torque) that reved to 8500 rpm (red-lined at 10,000 rpm). Block was the same as used in Lotus Ford Cortinas. Spark was supplied by a custom built Mallory dual-point distributor, a home-built Capacitance Discharge module, and solid conductor Packhard 440 wires. To say that Holley-fed Cortina was a blast to drive, as a daily driver, would be an understatement. With my designed ram-tuned intake/exhaust, the engine was screaming at 6000 rpm, so you could imagine what it sounded like when it reached 8500 rpm. Crane Cams (Steve Edens) was very helpful in suggesting what cam grind to use as well as some lightweight parts for the valve train.
Best regards,
CJR
