Jeep is fixed here is the conclusion
Stalling was caused by a bad Crank Shaft Positioning Sensor.
High Idle was caused by two things 1. Bad Idler Air Valve 2. One of the previous shops I took it to modified the throttle cable to compensate for the bad idler air valve and the throttle cable was getting hung up.
