JMA_2001XJ
- New York
So on my 2001 XJ I have an random vacuum leak when I come off throttle. It is a high pitched whine only on deceleration with no throttle input. But it only happens sometimes and seems to be totally random. I can usually drive about 5 miles or so on a cold start before it will begin and then it will continue for the duration of my drive or sometimes it will just stop doing it after awhile. It does not do it at idle. Occasionally when I come to a complete stop it will continue for a little while. It will continue long enough that I traced it to the engine bay. I initially thought that it was coming from behind the dash and had to do with the HVAC system (the common vacuum leak area). But one day when it was doing it and I came to a stop and it continued, I opened my window and it got louder, I quickly popped the hood and it got much louder, and then abruptly stopped. I can't duplicate it without driving the Jeep.
My buddy has a smoke machine so I tried it out. The only place that smoke was coming out was the throttle body butterfly shaft, nowhere else and I let the machine run for 20+ minutes. I have read that the bushings can go bad, there did not seem to be much play in the shaft, but there was a pretty good amount of smoke coming out.
Before I go and buy a new throttle body, I was hoping that there was someone else that may have had this issue and can chime in. Thanks in advance.
