BulletMaker
- Cascades, WA
So I'm missing out on all the nice weather up in WA right now trying to get the wife's jeep up and running to pass smog so we can get on with the move (reg is currently out).
I havn't monkeyed with it much in a few months, but I need to get this thing up and running so I can take my truck back.
Anyways, there are two main issues, first of which is a high idle on startup, not the creep-up that there are tons of write-ups for, but you turn it on and it's spinning the engine at ~2000RPM. Didn't do this when we first bought it last year, but it's now a major issue.
Corrective action taken:
I went through and methodically replaced all vacuum lines, this one has an NP231, however since 4wd isn't needed ATM I disconnected the lines for the axle.
Seafoam'ed the intake and throttle body. More than a few write-ups suggested this as an issue, so I went through and cleaned every part I could get to with carb cleaner and a rag, then I turned it on and blew seafoam through the whole thing.
Engine/Chassis grounds - Many suggested this is also a common culprit, while the grounds were f-ed up, I replaced the whole mess, now has nice new marine terminals with a grounding connection to the main point (next to the dip-stick bracket. All connections cleaned with wire brush, coated in preservative, and new 4ga cables connected from battery to engine, and to chassis
New O2 Sensor - The one on there was pretty baked, put a new one in to help it pass smog.
Cleaned EGR system - Removed valve, filled full of crud cutter, jagged it out with wire brushes, turned it over to blow everything out. EGR seems to be working normally.
For giggles, I double checked the vacuum system, near as I can tell no leaks.
So, my main suspicions are that it's probably a bad IAC/TPS.
However, the NOx emissions from the first test were in the <800 range (almost passing). Now that this high idle issue has come up, it's now testing with NOx at about 1700.
Suggestions? Dispersions? Questions?
