Hi-Lift Mount.
Wayne Sihler
Maurertown,Va.
Have the Tomken rear bumper and Swinging tire carrier combo and want to add a Hi-Lift mount.
Tomken makes a bracket to mount the jack on an angle,but it doesn,t fit.Dont they check there own parts-------
Anyway is there a mount by someone else that would work? Holes need to be drilled to mount the Tomken mount so drilling is not a problem.Want the mount to be verticle (sp)
Thanks
Wayne
If you must have it mounted on the outside you can make your own mount with some standard bolts and spacers.
I like to have mine inside and I found it fits nicely where the back seat used to be. There's even stock holes there that line up with the Hi-lift.
Checked with Tomken,the mount I have was not intended for use with an XJ.4WheelDriveHardware is wrong in the catalog.
Tomken has a base mount that will work but I will need to fab a top mount.
Wayne
