help with a Hnt?
so...I'm trying to get my hands on a HnT SYE. so....first question:
is there anything else besides this kit to do this install? http://rubiconexpress.com/JeepParts/Product.aspx?part=RE1801
Second question:
is there anyone around me that would like to donate their expertise and time to showing me how to do this? This is over my head.
p.s. is there a cheaper one available?
Buy a JY 242 t-case. That would be sufficient for your lift.
Second question:
Fix your track bar first. I take it you made it home ok?
Craig
yea i did. thanks for askin. I'm actually ordering the HD upgrade for the trac bar from Rustys.
But running those trails made me want some more lift to really be able to flex out those 33s.
Just got off the phone with rustys, and he was sayin I was gonna need new UCAs and LCAs, and a drop pitman. Is that all really necessary for another 1.5 inches? That seems ridiculous.
Im not sure about lifts that big. But with upper and lowers you will be able to center your wheel in the wheel well and adjust your drive shaft angle alot easier.
so...turns out I'm gonna be getting the 96+ HnT from RE, and swapping in a TJ mainshaft and tail housing.
Will a stock front DS work in this situation?
I don't know. I've never dealt with the TJ mainshaft.(which I believe is shorter)
