Help so I can go to the Badlands Aug 5th
PM sent.
rockjock said:
I have some late model gm tow hooks in the sway bar holes are these strong enough to hold up to a pull? Not a yank but just and ease out. Maybe from a winch?
No, you need the proper brackets to tie them in to the unibody. I don't think you'd find anyone here to pull on them. I know I wouldn't.
rockjock said:
Well I guess I need the brackets. Where can I get those on the cheap?
Scott
Try rustysoffroad.com
or
http://cgi.ebay.com/ebaymotors/Jeep-XJ-Cherokee-Wagoneer-MOPAR-Tow-Hook-Brackets_W0QQcmdZViewItemQQcategoryZ33653QQihZ014QQitemZ330005189001QQrdZ1
or
http://cgi.ebay.com/ebaymotors/1984-2001-Jeep-XJ-Cherokee-Front-Tow-Hook-Kit-NEW_W0QQcmdZViewItemQQcategoryZ33653QQihZ007QQitemZ170004241242QQrdZ1
Don't know about this one, dif design than I have ever seen
NEVER MIND THIS ONEhttp://cgi.ebay.com/ebaymotors/Jeep...tegoryZ33653QQihZ007QQitemZ170006025408QQrdZ1
As for the rear you can get a hitch, somone there will have a reciever d-ring you can use if you get stuck.
Mambeu said:
I wouldn't trust a tow hook that advertises itself by saying "makes a great rugged appearance on your Jeep".
Yea I thought about not putting that one on there, I can't even see how they mount to an xj anyway.
Now...THOSE are some scary looking brackets. Stamped steel maybe? The hooks may handle 10K...but the brackets look like they are good for about 5.....pounds that is.
Rev
I can't figure it out either. I sent the seller an email asking about it:
me said:
How do these tow hooks mount? Do they end up in the stock location (under the bumper)? I'm trying to figure out what the brackets would be bolted to; if you have a picture of an installed bracket that would be really helpful.
Thanks,
Matt
rockjock said:
What about factory tow hook brackets? I found some. Would these be strong enough?
They are your best bet for a cheap and easy solution.
X2
I used factory hooks till I got my bumper. Worked great for me.
Haleyes said:
X2
I stil use the factory hooks, and I saw Pauls XJ take some wicked pulls on the factory hooks at redbird. I'd trust factory ones.
