Ecomike
NAXJA# 2091
- MilkyWay Galaxy
I could not find my fuel pressure tester. nor my 2nd cps.
I did push the shrader valve down with the key in. and did not get a spirt of fuel.
popped the hose off. and there was fuel in the rail. a lot leaked out.
Should it spray out if the key is in the on position ?
may I actually have a fuel issue ?
That adds to my earlier diagnosis of a possible leaking FPR, since you later said you have 39 psi at the rail.
