bradlyw
- Stillwater, OK
Background Info: '87 XJ 4.0L AW4
welll to put it simply i guess, i cant get any airflow out of my vents. The only time i can get any airflow at all is when the Jeep is moving i get a very very small amount of air through the defrost. And the pressure of the air doesnt change when i turn the airflow "dial" from low to high or anything in between.
Now, i've found a couple leaking vacuum lines and fixed those, and now i just dont get any air at all. No matter what setting its on, i cannot get any flow at all out any of the vents.
Winter is on its way and i'm freaking out thinking i'm not going to be able to get the heat working by then. So any and all help is appreciated. Thanks
Brad
Brad
