KJWildman
- Toledo, Ohio
I have a '91 XJ, 4.0HO , 4" IRO long arm and a bunch of other stuff done, but now I'm having problems with my headlights. My XJ is my DD and I work 2nd shift. I drive home (depending on o.t.) between midnight and 4am about 45 miles through NW Ohio farm country with corn, wheat and soybean fields almost the whole way, along with the occasional farmhouse. LOTS OF DEER!
I recently replaced my headlights with led lights and made a huge difference in how many deer I see before they jump out in front of me! My problem started last week when I dropped from hi beam to low beams for an oncoming car. MY LIGHTS WENT COMPLETELY OUT!!!!!! I played with the turn signal stalk flipping from hi to lo and back several times and they came back on. .....okay, I think it must be the switch. Got a replacement switch from NAPA and installed it this past weekend. I thought I was good! WRONG! Last night it happened again! Luckily the roads I drive are straight and flat.
So, the headlights have been changed, the switch at the base of the steering column for hi/lo beam has been changed, I checked for good grounds. Is there a main headlight relay that may be going bad? I don't think it's the dashboard headlight switch because they go back on if I flip the hi/lo beams on and off, I never touched the dash switch. Doesn't happen very often but could I have gotten a bad switch from NAPA out of the box? Do I need to try and adjust it differently?
HELP!!! I normally see 6-8 deer beside the road during the week and I don't need my lights to go out as I come up on one. I've hit 4 in the last year and a half ( named my XJ "The Deerslayer" !
) and I don't really want to hit another.
