Headed to the junkyard.
Lucky2BAlive
Knoxville TN
Ok guys I'm headed to pull-a-part to get a few things. What are some things to be on the look out there to do some mods on the XJ? Brackets, vents, fans, from different vehicles? anything hard to find? Anything expensive? Etc.
Help me out if you can.
Thanks
Grand Cherokee V8 Tie rod is beefier
Chevy 1500 front brake lines are longer
Dodge Ram rear shackles will give you 2" (you'll need to even out the front - look at coil spring spacers from the Firebird, Camaro, Thunderbird, etc)
Hood vents from Grand Prix GT will help with cooling - oh hold it, I have a set for sale - PM me!!
Transmission cooler from an Explorer
Grand Cherokee alternator is higher voltage (will need to upgrade wiring)
Durango steering box is stouter (will need a spacer)
Skid plates are usually available for dirt cheap (rear, front, t-case) The front and t-case are universal. Rears only fit one body type - 84-96 or 97-01
196#~2002 dodge D-60 rear axle is a bolt in to an XJ.
Any ECU, TCU, throttle body, etc
Renix a/c delete pulley.
Look out for late models, stuff like the infinity tweeters, overhead consoles and whatnot are desirable.
Ford Taurus fan if you want to do a e-fan setup for cheap
I try to keep an open mind and look at different stuff at the junkyard and let imagination wander! I have picked up a wide variety of stuff that someone ends up using, and almost got a set of Discovery fold up seats this way... still kinda regretting that.
Oh yeah, here is plenty of reading you can do for the junkyard : http://naxja.org/forum/showthread.php?t=66012&highlight=junkyard+upgrades
