Yes, they'll fit, but be aware that the headlight wiring of XJ's can be pretty marginal, so if they pull a lot of extra current you may get voltage drop. If they're reasonably close to the original wattage it should be plug and play.
Hahahaha, I'm sure when I get it running again(soon I hope) that I could put it back in the lake and do a little night fishing... Suppose to be sealed he said...
65/55 refers to wattage, so they are either 65/55 OR they are 90/100 watt ... they can't be both. 65/55 should be okay with stock wiring, but if they are 90/100 you should rewire with heavier gauge wires and relays.
