More or less direct at flash but anyone who knows please jump in. Is the amout milled off the deck be a 1:1 ration of raising the rocker arm or does the geomerty require something different. I am guessing, alignment of push rod is not true perpenidicular to crank and pistons so it would not be a true 1:1 or then again it might be so close you can go with 1:1. I wish i could read blueprints and paid a bit more attention in trig and geometry in High School!
I was also intrigue by the Head gasket/zero deck suggest posed by the last poster.
I have a hesco head on DD XJ with the general air/exhaust mods. I running a stock TB(with spacer) though but fuel mixture is good. I am close enough to B'ham, I ll probably let them do the block though I am sure it will not be cheap. Lord knows the head wasn't.
I was building what I call light/moderate trail rig and had not plan to stroke it. My DD driver is stroker canidate one day and I have learn a great deal off this thread for both engines when the time comes. Thanks
