I see that the NAPA clutch is 0.15" taller from the spec sheets. Does anyone know about the autozone or advance brands, are the same, taller, or shorter than the stock FC?
Has anyone here done this upgrade on a renix jeep?
If so which radiator did you have, and what if any problems did you have installing it (clearance), or clearing the radiator?
I am starting to get the impression that the Renix radiators may be slightly closer to the stock clutch than the HO engines?
Are the shrouds different between Renix and HO?
And FYI, the fan mount height on the stock and HD NAPA clutches discussed here differ by .35" as well the overall 0.15" difference in overall clutch height.
I can barely install my stock clutch on my Renix with out moving the radiator off it's mounts on the top side (to lean it back enough to clear the studs) and I have a 1 row aluminum radiators.com radiator.
Mudderoy,
I have never had my jeep run hot here in Houston, not in 4 years, but the last few days have had me shivering as the system has peaked up to numbers like 235 F idle in the driveway at the thermo housing, in park with the AC on. It never got over 200 F before this week. I hear it hit 104 F here yesterday, 108 F heat index!
