Well right now I'm using a zj pitman arm witch drops down about and inch. from that I'm using V8 zj parts down to the knucle and of the drag link to the driverside knuckle i'm using 1/2 ton dodge parts since they fit the stock taper of the knuckles and they are 3/4-16 witch is a comen tap and also the same as a 3/4 hiem joint.It work great at 4.5 inches but at 6+ I don't care for it and now getting ready to do over the knuckle. In a previous post some one mentioned doing an inverted y out of dom. I have it worked out if some one is interested.
