Root Moose
- ON, Canada
Jon, have you had good results with your AW4 rebuilds?
The AW4 is a fairly simple box - and a "Master" rebuild kit (including clutches, steels, and whatever) goes for about $300 locally, or a "Overhaul" kit (basically a reseal kit and components to renew the valve body) for about $90 - both at the tranny shop up the street from me here.
You will need two "special" tools that I was able to make from bulk stock - there are some very large snap rings (which won't work with standard snapring pliers - I made a part of "chopsticks" using 1/4" aluminum round rod and D&T for #4-40 setscrews) that worked well, and get a decent bit of barstock and some M10x1.5 and M8-something (I don't remember what) and some 1/2-20 allthread to make the bridge puller to pull the planetary sets out. If you need me to, I can probably dig them up and take digipix for you sometime in the next couple days.
Total cost for "special" tools - about $20, all up.
You MUST have a camera capable of giving you pictures straight away for any valve body work - since there seem to be a few revisions of what goes where, and the manual isn't always right. I should have the ATSG AW4 manual around here somewhere as a .pdf (it's the one I used - and I found it online somewhere. Probably at Strokers - groups.yahoo.com/group/strokers) which has everything else correct - I've just never trusted manual pix of valve bodies (and I'm usually rewarded for that lack of trust.)
The three valve body solenoids can be readily checked with an ohmmeter - as I recall, 13 +-3 ohms is nominal. Hopefully, they're fine - they're spendy to replace (and I haven't been able to build up a stock.)
With either renewal kit, you WILL have valve body gaskets left over - it's a kit for all AW4 variants (Celica, Supra, Pickup, Van, XJ, MJ, ...) and you will match the gaskets up against the old ones to select them.
Results? I did the transmission in my wife's 89 about 80Kmiles ago - no complaints.
5-90
Has anyone ever actually purcahsed an AW4 from these guys?
http://www.teamcherokee.com/Transmission/index.html
If so, do you have anything to say? Thanks
The AW4 is a fairly robust transmission. Most problems such as shifting are relatively easy electronic issues and not mechanical. Why are you looking to replace it?
If you truly need to replace it, I would recommend getting a used lower mileage tranny from the salvage yard. Rent a tranny jack for the weekend and spend a saturday swapping it. $100-$300 for the tranny if they pull it, less if you do, $50 for the tranny jack rent, couple cases of beer for the mechanically friend(s) you invite over to help.
While it says new, it is likely to have been sitting for many years, unused, which is not good for floating rubber shaft seals, etc.
Too rich for my blood, think how many years it may have sat in storage.
Kind of like a virgin old maid? Sounds good until you try and give it a good romp?
