chedisme
- middletown, NY
thanks bud. i might actually win this one!
Threw a vote your way!
so I only have a roset or two left on the driver side. I was getting pretty frustrated welding I thought I was doing terrible. but I think I was just hitting the duty cycle. I would be welding fine pretty nice beads for me at least. and then all of a sudden it was like the wire speed was way too high. does that sound like I was dutying it out?
If you have your welder where it's dusty as shit every now and then you have to blow out the liner or what you're describing happens, to me at least. Cut the wire inside the welder, pull it out from the tip and stick a blow gun in the liner and blow it out. Feed the wire back in, try it out then. I usually leave a paper towel clipped to my wire in the welder before the rollers. It glides on the wire and cleans it as you weld, keeps dust out. I also throw those little white packets that you get in shoe boxes or whatever to keep moisture out. I've never had a problem with worn rollers, yet.
Look at you. Im sure thats what it is. Its really dusty in my tent with all the grinding. And the moisture lever might be abit high too.
