Harmonic Balancer - bolt stripped.
ParadiseXJ
Last week I finished my harmonic balancer install and it went fairly well. I had not torqued it down because it started raining and I figured I'd just finish it the next day.
So my problem is it WON'T torque down. It just spins. I noticed that the end of the bolt is chewed up. Can I use a shorter bolt or should I re-tap the crank snout...and if so should tap it 1/2" x 20 or??
Any answers? I wanna drive the mutha'.
Sounds like you tried to use the bolt to pull the harmonic balancer on. I would try installing the balancer properly and then a new bolt might reach far enough in to capture threads that aren't stripped out.
In short, here's what I ended up doing after the previous owner stripped out most of the crank threads. Much easier job with bumper removed.
1) buy 2 (just in case) long grade 8 bolts from http://mcmaster.com
2) buy bottom tap to open up some threads in crank
3) J.B. Weld long bolt in crank shaft hole, let J.B. cure, cut off end leaving 4+ inches of bolt shaft sticking out
4) Install new harmonic balancer using stacked, greased washers, and proper nut , leave end of bolt sticking out of crank, you will need it it you ever want to remove the H.B. again
Good luck,
Mike
Good luck,
Mike
Put a nut or a die on the long bolt before you epoxy it into place. Then after you cut the head off to make it a stud, you cut run the nut/die off the end to help reform the threads. Little trick I've learned along the way.
Being a machinist, I say you drill out the snout and insert a helicoil. If you are going to fix it, you might as well do is right.
True, but that is a much more daunting task for the non-machinist. In all likelyhood, it's just the end 2-3 threads that got ripped out and once the balancer is on there is probably at least 1-dia worth of threads engaged. Epoxying in a stud is a quick fix.
Pull the HB--yeah, sucks right.
Inspect the damage.
Run a tap--clean up what remains of the threads.
THEN decide what you want to do.
I do, however, lean towards Heli-Coil.
Actually, pulling the HB is what I had in mind even if I was going to either tap it or if I had to drill it. The threads are fine for the first 1" to 3/4". The HB is flush with the snout. Then the one big washer, then the bolt.
Not being a machinst, and never having done a helicoil 1.) how much would I have to drill and 2.) does that change the size of the bolt? and 3.) how the fritz did I screw this up.
3--not a clue, if you had short-started the bolt the outer threads would be toast.
2--you purchase a Heli-Coil kit for the original size bolt, it comes with the correct tap and the correct drill size is indicated.
1--as deep as the hole for the bolt is, no deeper.
I think I got out easy, read on.
Inspect the damage.
This is good advice because this is what I did. I just ran the same thread tap. I think there were just a few crinkled threads at the end. I had worried that I may have cracked the crank snout, but there's no evidence of that.
Ran tap, bought new bolt, torqued down to 80 fp. Went for a drive.
None of the ones I looked at did...at NAPA.
