GrimmJeeper
- Gardena, CA
87 MJ 4.0 2wd ba-10
this just started yesterday, and is getting progressivley worse. it cranks extremely slow, like the battery is dead. i put a volt meter on the battery and it shows 13.4 volts. im thinking maybe a bad ground?
another oddity... when i put the directional signals on, the voltage gauge dips when the signals flash. maybe alternator going bad? once it starts it runs fine, and i can pull the ground cable off the battery and it stays running. if the alternator was going out it would die, wouldnt it?
