YELLAHEEP
- Littleton, Colorado
Ok, '93 HO w/ 5sp. New: plugs, cap, rotor, wires, CPS, MAP, temp sensors.
Had an intermittent problem with a crank but no fire problem. Would start after a few turns of the Ign. key. Now today, would crank all day long, but no fire. Has spark, and fuel pressure to the rail (checked buy pulling the fuel lines and there was fuel in 'em) but not a bunch of pressure. Fuel pump relay is working fine, I can hear the fuel pump buzz when turning the key, all other relays and fuses in the block are good.
What it does now is: Won't start by just turning the key. Will start if I turn the key with the accelerator mashed to the floor. It stays running after that.
What's causing this condition? Fuel filter getting clogged? Fuel pump going bad?
Thanks in advance!
Troy
Thanks in advance!
Troy
